Old 06-17-2012, 09:56 PM
themaddhatter themaddhatter is offline
Default QL engine lift bracket ?
Alright, trying to undo some things on my 1450s.
- On top the engine, there is "supposed" to be a lift bracket which goes through the head and into the block via a stud, correct?
I have the stud, but the PO had "fabbed" some sort of support tie-in for the QL muffler (most definitely doesn't look "stock"). I am going to be making a support strut that ties to the front of the block.
Anyone have a picture of what it is "supposed" to look?
Is the only purpose of the stud to attach that bracket? I had already backed the stud out, so I can just put in a head bolt.
I have a little time, as I have to take the warp out of my head. Picking up some glass tomorrow.
Old 06-18-2012, 10:55 AM
Anyone?
Bueller?
Bueller?
Old 06-18-2012, 04:34 PM
jcsmith jcsmith is offline
Default lift bracket
on my 104 the lift bracket is a simple L shape,
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 06-18-2012, 04:50 PM
The lift I use on all Kohler K engines is the starter and carb!!
I have never used that tab.
Maybe when I get a little older!!
Old 06-18-2012, 04:52 PM
Donovan M.'s Avatar
L shape with a 3/8s hole.
Donovan:
62' Original-fenders
Old 06-18-2012, 09:26 PM
Merk Merk is offline
by CADplans
Brave soul to lift an engine by using the carb for a handle. The carb is the last place I would l would grab to pick a engine up.
themaddhatter:
Can you post a picture of the lift you have on the engine?
Check page 3 and 7 on this manual:
http://www.onlycubcadets.net/pdf/QL%20Op%20Manual.pdf
It have a picture of the lift point.
Old 06-18-2012, 09:32 PM
+1
I have had several parts carbs with the mounting ears broken off...guess how that probably happened.
Old 06-18-2012, 09:45 PM
+1
If you want to recommend a solution, recommend!!
I will be 62 in July, give your opinion, don't mommy me. Thanks
For me, I grab a K engine and lift it!! Whatever I grab, I guess is my business!
Old 06-18-2012, 10:08 PM
Exhaust elbow and starter or starter/generator, as equipped. Or the hoist bracket that is the topic of this thread.
Old 06-18-2012, 10:42 PM
gardenpest's Avatar
gardenpest gardenpest is offline
What I do is remove spark , insert little finger into hole ,curl tip of finger and lift out engine.........yea , I think the L bracket is the way to go..........
149..... qa-42 snow thrower..#1 tiller w/extentions, 109 w/deck, 129 w/blade 1450 w/deck
Case 444 gt.....H270 toro wheelhorse....Massey 135 diesel.....52 GMC
