Old 06-08-2012, 04:31 AM
fonty fonty is offline
Default Stock Tire Size for 1450
Can anyone tell me what the stock tire size is for my 1450? As you can see I bought it without rubber so I have nothing to go on.
Sources for tires would also be helpful.
I also need to know what kind of hydraulic fluid to use on it as the system is dry at this time.
The motor is dry but I assume that 10-30w would be sufficient for that.
Thank you in advance
Bill
Old 06-08-2012, 06:45 AM
cub123's Avatar
cub123 cub123 is offline
Given it has the stock rims, it takes 23 10.50-12 on the rear and 16 6.50-8 front. The hydrostatic system takes non synthetic hy trans that you can get at your local cub dealer.
Old 06-08-2012, 07:30 AM
This is the recommended Hydro Fluid............. Hydro Fluid
This is the recommended Kohler lubricants.......... Engine Oil
Old 06-08-2012, 08:41 AM
superduty5.9's Avatar
superduty5.9 superduty5.9 is offline
Do not use 10W30! Use SAE30 instead.
1200, 1450, Red 782
Old 06-08-2012, 12:04 PM
Default Tires and fluid information
Thank you for the information.
I will get the SAE 30 and HYTRAN from a cub dealer
Hopefully tractor supply will have the tires at a reasonable price.
Old 06-08-2012, 01:43 PM
EarlJ's Avatar
EarlJ EarlJ is offline
http://www.millertire.com/about-us/ They have pretty good prices and have both turf and ag tires..
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 06-09-2012, 01:18 PM
Default Hytran
I called the local Cub Cadet dealer today (huge dealer been in business long time) and they don't carry HYTran oil. They said that Cub Cadet and International are 2 different things and that my machine is likely a International Cub and not a International Cub Cadet.. Of course I quickly corrected them as it says "International Cub Cadet" on it and that I understood that the Cub Cadets of today are different.
Oh well, you can rest assured that I will not be putting much weight on any of their opinions.
Old 06-09-2012, 05:41 PM
Your dealer should have the correct tranny fluid. Most of the dealers don't know the old Cub Cadets. Mine sure doesn't.
Old 06-09-2012, 05:50 PM
I would be going elsewhere. Do you have an Case IH dealer around your area? They would have it in a barrel, and from what I've heard, cheaper to.
Old 06-10-2012, 02:27 AM
Default HyTran compatible Fluid
Has anyone used Traveller® Universal Tractor Trans/Hydraulic Fluid that is sold at tractor supply?
It indicates on the package that it is recommended for:
Case HY-TRAN Ultra (MS-1209)
Case HY-TRAN Plus (MS-1207)
Case TCH Fluid MS-1210 (JIC 145)
International Harvester HY-TRAN B-6
International Harvester HY-TRANS Plus (MS-1207)
To name just a few.
The cub manual states HY-Tran B-6 which is listed
