Old 05-31-2012, 09:02 AM
yesmar74's Avatar
yesmar74 yesmar74 is offline
Default carb kit
Trying to find a carb rebuild kit for my K321 and my local CC dealer told me it's no longer available. I was also told to check Car Quest but I got the same story. I'm having a hard time with that!!! Were is a good place to look?
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
Old 05-31-2012, 09:49 AM
badboy1950 badboy1950 is offline
Default carb kit
try one of our sponsors at the top of the page, i have purchased from cub classics and recommend them.
Dan
Old 05-31-2012, 10:06 AM
You don't say which K-321 spec number, or tractor model that you are referencing.
Add'l information would be most helpful....
Old 05-31-2012, 10:52 AM
tractordude tractordude is offline
The kohler part # is 25 757 01-S, stens # 520-213, any small engine shop should have one in stock
Old 05-31-2012, 11:15 AM
jkier's Avatar
jkier jkier is offline
You can get them from NAPA
http://www.napaonline.com/Catalog/Re...Dp%3d3%26N%3d0
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 05-31-2012, 12:24 PM
According to Kohler, there are two different kits available for the K-321 depending on the Spec Number.
Old 05-31-2012, 01:26 PM
oops, forgot about that. engines with walbro carbs are 25 757 11-S, kohler carbs are 25 757 01-S
Old 06-01-2012, 07:47 AM
nikster's Avatar
nikster nikster is offline
You, got mine from NAPA, ordered it by phone (9:00am). Had it by 3:30pm.
Nik,
