Old 05-13-2012, 10:34 PM
CubNub's Avatar
CubNub CubNub is offline
Default 782 Rebuild
So I'm starting my 782 rebuild. Pulled the engine a couple fenders and the seat. Thought the engine was seized because I couldn't turn it but put a light extra into and and it budged. Guess it was just stuck and now it moves with no problem. I think I may completely tear down the series I clean it and give it a nice paint job. When I have it apart and if it doesn't seem to be worth rebuilding what is a good donor for the 782? As I pull it more apart I posted updated pictures.
Old 05-13-2012, 10:59 PM
You've been busy! Looking forward to your progress.
Old 05-14-2012, 01:36 AM
Me too!
Old 05-14-2012, 12:59 PM
cub1450's Avatar
cub1450 cub1450 is offline
Looks like a good start!
A M18 is a common replacement for the kt series one or you could put a series 2 in it.
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
Old 05-27-2012, 11:34 PM
CubNub's Avatar
Had a couple hours to spend on the 782 this weekend and made some decent progress. Pretty much have it down to frame. Only thing I think I have left on there is the lift which I may just keep on there. Just going to give it a thorough cleaning and maybe some fresh paint. Can or should the lift be able to be moved if its completely torn down? I tried moving it and it won't move at all! I was also thinking while I have it torn down of putting in the two front ports, does anyone have any pictures of theres or a how to?
Not the most ideal work conditions but I dont take the time to clean up and make a nice setup for myself. Just want to jump right into the cub!
Old 05-28-2012, 09:28 PM
Donovan M.'s Avatar
Weres the diesel???????????????
Donovan:
62' Original-fenders
Old 05-28-2012, 09:30 PM
Where's the V-twin?
Old 05-29-2012, 08:44 AM
cub1782's Avatar
cub1782 cub1782 is offline
Give ole donovan a break he'll be getting it soon
Logan Pfeiffer
1986 cub cadet 1606 w/ spring assist, cat 0
1974 cub cadet 149 sleeve hitch
1984 gravely 5665 professional
1979 gravely 8122
1979 gravely 8102
2000 Exmark lazer Z
1978 international 184
Proud to be a member of the FFA
Old 05-29-2012, 08:58 AM
Thanks for the update!
Old 02-11-2013, 07:45 PM
CubNub's Avatar
Had a couple weekends to work on the 782 and did some priming. Also a shot of the new engine shes getting. So much easier taking it apart then its going to be putting back together. I know I'm going to have extras parts
