Old 05-18-2012, 10:19 PM
Default It's alive, but
Worked on the 100 tonight a little. Started it and let it get up to temp. to do some adjusting of the carb. Running real good. Then I went into the house for supper and came back out. OIL on the floor
What the h%&@? Lifted it up and seems to be leaking from the left rear corner of the oil pan. It dripped down on the frame then to the floor. I screwed something up again, DANG!
So I'm thinking I'll need to pull the engine again, that's not what I was looking forward to, but it's all a part of building something from the ground up, I know it should only be done once, but I'll look at it as a learning thing, can never know to much I guess.
But I just don't understand what could be wrong, other than the pan gasket, I'm sure I torqed the pan bolts, and used the same ones, so their not a different bolt that could of bottomed out, nothing like that. Well I'll have to check into it more later, sorry so boring, but I needed to vent, hopefully tomorrows road trip will calm me down some.
Old 05-18-2012, 10:23 PM
johncub7172's Avatar
Man, if you used that blue rtv silicone garbage on that pan gasket - I'am going to flip out.
Old 05-18-2012, 10:58 PM
No a factory gasket.
Old 05-19-2012, 12:02 AM
Todd might the oil pan have a crack in it? I hope it's a easy fix for ya!
Old 05-19-2012, 07:58 PM
Flatbedford's Avatar
That sucks! Just remember that you are doing this because it is fun and it makes you happy. Going back to fix stuff is never fun, but it is an unfortunate part of our hobby. At least you aren't counting on the machine to make a living.
Chin up! It will be fine.
Steve,
Former multiple 149 owner.
Old 05-19-2012, 08:21 PM
Went out to the shop and took the front off the 100, but just made me about sick looking at it, so I'm in the house and going to watch the All Star race on Speed tonight.
Duke, the pan was fine when I took it off, and I never did anything to it that I remember. I'm hoping I just messed up the gasket as I put it on, don't know how I could of messed that up, but somethings wrong, that ain't right
Old 05-19-2012, 10:15 PM
Sugarmaker's Avatar
Todd,
Hope you find the cause of this leak quickly and painlessly.
Good talking with you tonight.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 05-20-2012, 12:54 AM
I'm hoping it's a easy fix for ya!
Old 05-20-2012, 09:37 AM
Me too.
Old 05-20-2012, 02:53 PM
Must be you put it on dry then? No big deal at all. Just use a new pan gasket and Permatex Indian Head gasket cement.
