I'm looking to rebuild my whole steering setup on my 169. I want to rebuild the column and replace all 4 ball joints. I want it to be upgraded. I want to do the super steer upgrade and put Heim joint in. Could someone tell me where the best place to get this stuff? and what all I'll need. Also do you recommend doing anything else? thanks
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
Take a look at this site. This is where I got them for my 1650. They work great and I have not had any problems with them. They seem to have a good price on them.
http://www.bmikarts.com/item/3-8-24-...End-420021-576 |
I get mine from here http://www.mcmaster.com/#ball-joint-rod-ends/=hj18w6.
Matt G posted this on another thread. I got the lubrication free type.
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains 106-42"deck 1250-44 and 50" decks 147-44"deck 2155-42"snowblower 38"deck, chains,suitcase weights Exmark Quest-zero turn 42"deck 23hp Kawasaki engine |
I have also seen that there is a bearing that you can put in the top of the column (by the steering wheel) to replace the nylon bearing with a ball bearing setup. I saw it on a pulling website but i do not know what the bearing number would be. i would like to know the number for someplace like McMaster Carr.
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood. |
Heres how I beefed up the 86 and 108 .
Those look great. Did you make the tie rod?
John
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
