Old 05-10-2012, 10:06 PM
LukeH's Avatar
LukeH LukeH is offline
Default "O"s with lights
Is there a original part for a on/off switch for the lights? If there isn't, how did you do your switch if you have one.
Old 05-11-2012, 12:11 AM
For the NF's there is a light switch. Here's a pic of some I sold last year.
Sorry no more for sale.
Old 05-11-2012, 12:15 AM
From my understanding, the wiring diagram had them mounted kind of under the battery box on the driver's LHS, but toward the engine.
Old 05-11-2012, 12:17 AM
LukeH's Avatar
Thanks for the picture. Where on the console is it supposed to go?
Old 05-11-2012, 12:23 AM
From the file server. It's the direct download.
I just drilled my holes a couple of days ago. I had to zoom the pdf to see where I needed to drill the holes. I drilled 3 castings and 2 dash towers and had no problems. On the grills I located the top hole and clamped the light bracket on the grill and used that to line up the bottom hole. That way I knew the hole were in the right place for the brackets.
http://ccmanuals.info/pdf/O%20Light%20Install.pdf
Old 05-11-2012, 06:23 AM
LukeH's Avatar
Thanks guys
Old 05-11-2012, 08:26 AM
Your welcome!
Old 05-11-2012, 10:42 AM
Funny thing my parts manual dated 1963 shows it being on the right.
Old 05-11-2012, 03:04 PM
LukeH's Avatar
I just got a set of lights for mine so any info will help me install them.
Old 05-11-2012, 05:26 PM
That would make it the only cub with them mounted on the right side. I guess that it depends on the serial number on location of the switch.
