Old 05-03-2012, 10:56 AM
dbuck dbuck is offline
Default Any CC 149 owners out there?
Question about the hood hold downs on a 149. My hood brace has groves in it where the hold down contacts it. Are they suppose to be there or should the brace be without the groves? Thank you for your time. Don B.
Old 05-03-2012, 01:42 PM
AMCJavelin74 AMCJavelin74 is offline
I have a 128 (12hp gear drive, yours is 14hp hydrostatic drive, otherwise pretty much the same) and I don't see any hold downs... maybe I'm missing a few pieces. My tractor is an original neglected 128, now it's a better maintained but well worn 128.
CC 128 (Sept. 74)... and other vintage non-CC LT/GTs.
Old 05-03-2012, 01:53 PM
There shouldn't be any grooves. Time to do a bit of welding to build it back up. I had to do that on my 128.
Old 05-03-2012, 02:02 PM
You can see the hood latch hanging down on the steering tower. There is a catch up in behind the fiberglass dash that they rest on to hold the hood down. Hanging down allows the hood to be raised.
Old 05-03-2012, 07:17 PM
I have welded up the grooves in my 149 and 169.
I even put a little spot on the latch wires also to build them back up.
Old 05-03-2012, 08:36 PM
ajcombs's Avatar
ajcombs ajcombs is offline
Dude thats a beauty!
Old 05-03-2012, 09:47 PM
wj-ihc's Avatar
wj-ihc wj-ihc is offline
Do most of you guys use your hold downs and do they seem to keep the hood from shaking and rattling on your 1x8/1x9 series tractors? I have taken them off of a couple of mine because I have had issues with them catching on the hood when raising and lowering. I may need to make some adjustments to my grill in order to properly position the hood with respect to the dash, and I know I need to do some fiberglass work on the dashes to tighen fhings up.
5x Originals, one with rear PTO, 70, 2x 100's, one w/ creeper,2x 102's, 2x 122 w/creeper and rear pto, 2x 123's, 105, 125 w/ aux hyd,2x 73's, 126, 2x 147, 86, 2x 108's, 129, 2x 149's, 169, 3x 800's, 2x 1100's, 1250, 3x 1650's, 682, 2x 782's, 782D, 982 w/60" Haban, 1872 w/ Haban deck
2 Rear Tillers, 1 Snowblower, #1 cart and 2x #2 cart
IH/Cub Cadet 79C Chipper
526 Front Tine Tiller
Brinly plow, disk, grader blade
Old 05-04-2012, 08:44 AM
Thumbs up
Thank you Gentlemen for your replies. Time to fire the welder up. That is one good lookin CC128. Don B.
Old 05-04-2012, 10:23 AM
Thanks, I may one day get it finished. Seems like something always comes up and takes away my finishing money.
Old 05-04-2012, 10:30 AM
Smile
You are Welcome. I know how that story goes, its always something. I have been looking for a CC128, has I have 3 hydro's and want a gear drive. Don B.
