Old 04-25-2012, 10:37 AM
cmatthew's Avatar
cmatthew cmatthew is offline
Default #26 carter carb woes!!
pulled the carb, soaked it and did a rebuild. floats in good floaty shape. put her back together and fuel was coming from the air cleaner. so i adjusted the tab on the float to make it ride lower. its at a pretty good angle down now. it stopped the leak. rode it around and fine tuned her. parked her and came back a few hours later and still no leaks. thought i had it. this morning though it was bad news. leaking out the air cleaner again. how much of an angle can i put on this float? as much as it takes before it starts to starve for fuel maybe?
Old 04-25-2012, 12:25 PM
Many people will tell you the float needs to be "level" or whatever the gauge requires.
The fuel level in the bowl effects engine performance.
I would bet there is a different problem.
Dirt, old rubber from a deteriorated line, defective needle or seat, the list goes on and on.
Sorry, I do not think I could be lucky enough to hit the one answer.
Old 04-25-2012, 02:18 PM
jbrewer's Avatar
jbrewer jbrewer is offline
has the seat and needle been cleaned/replaced during the rebuild.
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 04-25-2012, 02:37 PM
cmatthew's Avatar
the float valve and seat is new. i noticed that the new float valve has a rubber tip on it where it contacts the float tab. new seals, new high rev needle, and throttle bushing. how tight should the float valve seat be in the carb body. i have it pretty snug right now.
Old 04-25-2012, 02:59 PM
jbrewer's Avatar
It shouldn't need to be that tight.. .I think there's an oring around it isn't there?
You sure that float is good?
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 04-25-2012, 03:50 PM
maddog784's Avatar
Mine was leaking gas and I discovered that my fuel bowl breather drilling was clogged. Might be something easy to look at.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 04-25-2012, 05:01 PM
cmatthew's Avatar
there is an o-ring and it is made of metal same as the one that came out. all holes were blown out with air. i will check the float again and make sure there is nothing stuck in the float valve.
Old 04-25-2012, 05:41 PM
Unless this is a carb needle like I've never seen before and has a rubber tip on each end, you've got the needle in backwards, and I'd have to wonder how it's sealing at all.
Old 04-25-2012, 05:44 PM
red56turbo's Avatar
On the carbs I've rebuilt, the needle valves did have a rubber tip. The end that contacted the actual float was still flat metal. Anybody else seen the needle valves with the rubber ends against a float? Maybe the wrong needle valve??? The rubber tip would go into the seat, not against the float. No offense, but it's not in backwards is it? Just throwing out ideas........
Snug the float valve seat. Don't over tighten. I've seen em stripped out by PO's with a little RTV applied . Good luck and keep us posted.
Dang Matt,
You type faster than me, LOL............
Josh
Diesel Cub Cadets...........
Old 04-25-2012, 06:38 PM
cmatthew's Avatar
k, that is exactly what is going on. its frickin in there backwards. boy.... do i feel like a schmuck! thanx for clearing this up fellas.
