Could you show pics of the hydro end. Does the hydro end leak like a faucet? I would be lead to believe that welding that end would melt the seal in that end cap. Some people just shouldn't be allowed to play with welders.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
![]() Quote:
The shaft isn't welded to the hydro. There is a flex disk joint at the hydro end. The weld I mentioned is at the "T" at the end of the shaft. That 1x4 (or so) plate that bolts to the flex disk is welded to the end of the shaft. What I want to do is make 2 more of these plates, cut a piece of the shaft out of the hub end, weld these plates to each end of the gap and mount a flex disk there at the hub.. In my mind, doing so would eliminate the need for the pin and slot in the hub, but I dunno. Anyone here make their own drive shaft?
LT1050 w/ 50" deck, 680 Hydro w/ 38" deck, 1450 w/ 50" deck, 109 w/ 38" deck 1A tiller, 42" snow blade (x2), cw-36 snow thrower, H42 snow thrower, #1 cart, 8" Brinly plow, Unk cultivator, Sears rear blade, extra k301, more extra decks and parts than space to put them. |
![]() Quote:
http://www.onlycubcadets.net/forum/s...ht=drive+shaft http://www.onlycubcadets.net/forum/s...ht=drive+shaft
Cub Cadet 129 48" deck - grass mowing 38" deck - backup deck 42" front blade |
