That's why we call him Link daddy!
You can also copy the text and paste into a simple notepad program. On a Mac, the links will be maintained and you can click on them from there. |
The first thing I'd do is find a rebuilt or rebuildable Kohler/Carter adjustable carb to replace that POS Walbro. A lot of those fixed-jet carbs run too lean.
Sorry for all the noob questions, but will these bolt up or will I need some kind of adapter plate?
It's a direct replacement.
Both my 1450 and 1650 have a black plastic spacer between the carb and the intake, it's about 1/8" thick as I remember. I don't know if it's there with your Walbro, and if you'd need it if you replace it with a Carter.
Here's what I addressed today. I recently plowed unknowingly with this 1650 for a short while with no incident. I found mouse house material coming out around the spark plug. If your grandpas tractor has been in a barn for 10 years you probably have an apartment complex in there.
A quick update, I got the carb pulled off. I then pulled off exhaust shield to find that the exhaust WASN'T ATTACHED to the engine!! No wonder it was so loud! I expect this accounts for all the heat as well. The little exhaust manifold was unscrewed (and seems smaller than the threaded hole in the engine, unless it has a pretty hefty taper), and the muffler wasn't clamped to the little manifold. The threads on the short little manifold look pretty buggered, I reckon finding a new one is in order.
There's also an extra muffler in the corner of the garage. Its times like this when I wish I could ask grandpa which muffler is old and which is new. I have a suspicion that whatever the source of the mystery, it has something to do with when grandpa first started to slip a bit years ago. Any advice on mounting new exhaust flanges? |
Maybe the muffler collapsed inside and is no longer flowing, hence someone unhooked it to keep on truckin'. If these mufflers won't flow out, a new one is in order.
