Old 04-06-2012, 03:31 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
Default 682 Hydro Trans Filter
See Pics. tell me what is right or wrong.
Doug
Original , 100 , 125 , 582
Old 04-06-2012, 03:42 PM
4SPEED's Avatar
and why is this pump yellow? is it a swap from another tractor?
Doug
Old 04-06-2012, 04:07 PM
The filter should say cub cadet on it, hehehe.I don't use cub ones, the case IH dealers have fleetguard# hf 6096.Maybe the pump was a changout or a leftover from the change from IH to CCC.
Old 04-06-2012, 04:16 PM
4SPEED's Avatar
Ok , what filter is right for my 682
the filter and rag joint almost hit. a paint stick is tight between them
Doug
Old 04-06-2012, 05:21 PM
Cub Cadet 923 3014 .I use fleetguard HF6096.lot cheaper.The spacing seems about right.Why did you remove the suction line?
Old 04-06-2012, 05:47 PM
Click here for the proper Hydro Filter..... Filters
Old 04-06-2012, 07:16 PM
4SPEED's Avatar
to put a new thingy on this side and a wacha call it on this side. leaks
also put a gasket on the rear cover. the PO and I had words the other day about this not having leaks
the engine sill has a leak I think its the oil lines to the filter.
I also did the Breather Assembly and made new gaskets for it. did the left side too.
Doug
Old 04-06-2012, 07:17 PM
4SPEED's Avatar
thats how I got the # for the Stens filter. thanks for posting that
Doug
Old 04-06-2012, 08:16 PM
Probably didn't leak for the PO cause it was empty
Old 04-06-2012, 08:27 PM
Then take out the paint stick
