What is the compression ratio on a stock k301 12hp kolher with 30 over pistion
its hard to say for sure ,when i rebuilt my 301 .030 over it had a bad c/r and it had 125 psi ,.so with a good c/r it came out with a 90 psi ,its hard to get very high ,because the exhaust valve stays open ,from .030 to .043 till it sets to 600 rpm ,so it you roll the engine backwards ,you will get the true reading ,hope this helps . David
Approx. 5.5-7.5 C.R. depending on what generation head.
I have the 4th gen head
Just google kohler compression ratio.
and you will get many hits |
