Old 10-17-2009, 01:42 AM
67hydro's Avatar
67hydro 67hydro is offline
Can you use the boiler for home water also?? Showers ect??
Jason
Jason Davis
Old 10-17-2009, 06:36 AM
The only thing that I would add is, make sure that you DO NOT run the Boiler and Oil Furnace at the same time.
Nice ole Thermal Pride furnace. See a lot of them around here (Michigan). They are built like a tank.
Old 10-17-2009, 10:00 AM
cub149's Avatar
cub149 cub149 is offline
I have that covered, not a problem.
Jason, yes I can heat the domestic hot water with this. It is also large enough to heat my 1500 sq ft shop. But for now I am concentrating on getting it hooked up to my house.
Thanks for all the help.
Old 01-24-2010, 05:44 PM
cub149's Avatar
Hey guys, I realized I never did update you on my progress on the heat exchanger and its final location. I went with the placement right over the oil burner in the supple line and it is working out great. No problems and have not used a drop of oil. This Outdoor wood furnace is the cats meow. We left for 5 days and I turned down the thermo to 55 and when we returned it still had some wood left. Of course it was in the high 40's. I can get 24 hours burn time when it is in the high 30's up. When it is colder, below freezing it does a solid 12 hours but when we had some 12 degree nights I was getting a solid 8-10 hours of burn time on one load of wood.
I did use some quick disconnects on the pex tubing. I will probably take it out over the summer months since it does restrict the air flow a little so my ac will be more efficient. Unless you have some suggestions on that.
I attached some pictures of my handiwork.
Thanks for the tips and advice.
Chip
