Old 03-14-2012, 12:55 AM
You've been busy, Doug! Keep up the good work.
Old 03-14-2012, 08:10 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
I want to get it back in roller before I work on the tin's . today I took the 8x12 rims off the 125 and saw they had tubes in them. one rim had a bad patch job on it , due to rust. I ground out the brass welds and re-welded the hole shut. its right at the valve stem so I'll need to drill a new hole.
I want the 8.5's on the 582 for plowing. the 10.5" I think are too wide for a 10 plow.
I ues a brass hammer as a backer to fill the hole with weld. weld wont stick to brass.
fronts
Doug
Original , 100 , 125 , 582
Old 03-14-2012, 10:23 PM
4SPEED's Avatar
also got this set of tred plates from a 145 ( maybe? ) its a hydro. guys is parting out. the tins on it look really good.
I'll need to cut a little on one of them and add a bolt hole. but they should work.
another part ready to go back on
Doug
Old 03-14-2012, 11:34 PM
Thanks for the update pics, Doug.
Old 03-14-2012, 11:38 PM
Looks good too!
Old 03-15-2012, 12:44 AM
149 - 498944's Avatar
149 - 498944 149 - 498944 is offline
awesome job. enjoying the pics
Cub Cadet 149 (Restoration Completed 2012)
Cub Cadet 149
Cub Cadet 127
Front Blade
1A Tiller
38" Mower Deck
44" Mower Deck
48" Scraper Blade
Plow
spare 12 HP Kohler
Old 03-15-2012, 09:42 PM
4SPEED's Avatar
Default How I took the stearing wheel off
I took the stearing column off , took off the end cap and bearings. set it on 2 blocks of wood. then took the nut loose (keeping a full nut), took a 3/4" socket 1/2" drive extension bar. put the socket on backwards and gave it a smack. it came off on the 3rd blow. had it socking in PB blaster for 2 days too.
Doug
Old 03-15-2012, 11:13 PM
Please keep us updated, Doug and keep the pics coming.
Old 03-16-2012, 01:10 PM
4SPEED's Avatar
Default Painted Wheels #902 White
Martin Senour paint code 99-10649-L #901 White
Doug
Old 03-16-2012, 01:32 PM
Your rims look nice!
