Old 03-05-2012, 08:47 AM
Todd, I hope you and the wall are fine today. Sorry to hear about your pto removal problems.
Old 03-05-2012, 10:00 PM
Sugarmaker's Avatar
Todd,
Yikes, the PTO had you down for a little while. I have had problems with them too. I think those small set screws take roots in those deep threaded holes.
Glad you got it apart.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 03-06-2012, 08:36 PM
Ok, PTO is off, you guys forgot to tell me (remind me) about the lock collar, before I beat the heck out of the pto trying to get it off!
Anyway after I cut the starter pulley to get the set screws out of the lock collar and starter pulley, and remembering to turn the lock collar I pounded the pto off and could get it into the drill press and drill out it's set screws. Finally!
Also used a piece of cardboard to put the removed head bolts in so I wouldn't try and put them in the wrong spots.
Also, I'm not going to be using this tractor for any pto driven attachments, so would I have to put the pto back on, or would it be a good idea to rebuild it and mount it anyway? If I wouldn't use it, what would go in it's place?
Thanks
Old 03-06-2012, 09:40 PM
Todd, before I forget it, there is a locking collar on the backside of the PTO bearing. Hope I'm not too late.
Sorry I had to do that. rof
Old 03-06-2012, 09:48 PM
Wow, glad you were on the ball DWayne
What's your opinion on my question of the pto?
Old 03-06-2012, 09:51 PM
No, you don't have to put it back on. The set screws hold your Gen/starter pulley in place.
I am not putting the PTO back on my nephew's 73. There won't be a reason for him to use it either.
You can also leave off your PTO lever and release button arm. Just that much less to deal with.
Old 03-06-2012, 09:56 PM
So I could use the pulley I buggered up? Just grind it down smooth, good to go?
Old 03-06-2012, 10:03 PM
Yep. Shouldn't be a problem.
Old 03-06-2012, 10:08 PM
Thanks DWayne
Old 03-06-2012, 10:19 PM
Thanks DWayne
No problem. That should save you some headaches finding another basket pulley.
