Old 12-16-2011, 12:31 PM
caind caind is offline
Default New to pulling
I would like to start pulling. I bought a 108 with a 12hp kohler, thinner head gasket, bored .030 , new rod and piston, cut valves, cheater cam, k&n air filter. It's suppose to all set up and ready to go pulling. The rear end is stock so should I be pulling in 2nd or 3rd gear depending on the track ? Hard packed track pull in 3rd ? and how do I place the weight ? Pulling in 950 and 1050 stock class.
Old 01-04-2012, 12:55 PM
hotya100 hotya100 is offline
First off, welcome to garden tractor pulling. Setups differ from track to track and even tractor to tractor. It usually takes the first year or so to get the tractor set up. Weight placement, track conditions, tire pressures, and finding the best line down the track are a few factors in a successful pull. Generally speaking on a hard track and loose track we have more weight on the rear, less on the front. On a wet, sticky track we put more weight on the front. When we pulled stock we couldn't use the stock 3rd, because it was too high. We pulled in 2nd mostly, and moved our weights around and played with tire pressures.
Larry
Cub Cadets -- 124, 129(149) with loader, 1000 V-twin puller, 1650, 2165, grandson's 72
Old 01-05-2012, 09:58 PM
weaverama weaverama is offline
I started out with a near stock tractor at my first event and just started talking to the guys. They knew I was a complete rookie but I always thanked them and offered to push there tractor up on the scales or was quick to lend a tool or hand. Soon enough , they started to help me figure out those things that I was clueless on. Within a few events and a couple more dollars, I was competitive in the stock classes. It seems that when you start to get up into the more "profitable" modified classes that the love stops and you will be on your own. You will figure it out.
Weaverama
Cub 108
Cub 1650
Cub 1000
Cub 682
Super Cub 2072
Old 01-15-2012, 10:16 PM
brucer95's Avatar
brucer95 brucer95 is offline
Just put it in 2nd put a tarp strap over the shifter and stand on on that throttle, the rest will come to ya. Weights vary greatly from track and tractor so its hard to say. The best advice I can say is find a tractor close to your set up and spy. Figure out what their running on the frontand pile the rest on the back.
129 Plower; 72 pile;122 daily driver, 2-42inch blades 42 inch deck- 06 GMC 1500 4wd- 1964 farmall 706
Old 01-15-2012, 11:01 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
I have never seen a garden tractor pull. sounds like fun.
