I recommend a heat gun -- mounting a tire in 80 -90 degrees temp as easy as pie, usually you don't even need the machine bar (mounting ) --50 degrees way different story as the rubber hardens -- also the black bead sealer is a good lube and then helps hold air ,I have used a little RTV silicone at times too
128 |
