Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 11-16-2011, 05:51 PM
LiamD's Avatar
LiamD LiamD is offline
Default Diesel oil and filter
Hi All,
What oil is suggested for winter use in the diesel models (1572) and which oil filter make and part number would be the best.
Also is there a manual that would be suggested, I did not get any manuals with my tractor.
Thank you,
Mike
Old 11-16-2011, 06:43 PM
I use Shell Rotella T 15W-40 in my 782D. I had many, many people recommend that to me when I bought the tractor.
Try here for manuals.
Old 11-16-2011, 07:17 PM
LiamD's Avatar
Default Diesel oil
Thanks Matt,
I will get the Rotella oil, I use the 30 weight in my gas engines already. The manual is great info. Do you happen too have the oil filter part number by chance?
Thanks again,
Mike
Old 11-16-2011, 08:18 PM
racenitro racenitro is offline
About the only diesels that don't use 15w40 are Detroits. The 15w40's have all the appropriate diesel fuel additives that are necessary for most diesel engines.
Detroits use straight 30W. Some changes based on weather conditions.
There are 4 major brands that you can rely on...Rotella T, Delo, Mobil and Motorcraft.
If you are a synthetic believer, than use one quart of synthetic for each oil change. Synthetic's major benefit is the fact that it stays on the bearing surfaces during shut downs and for very long periods of non use. Most regular oils will eventually drain off the surfaces after long non use periods.
There are other benefits, but this is the most obvious. This was told to me by an oil company representative years back at a major race.
Old 11-16-2011, 08:21 PM
I *think* the Purolator number is L14459, but that is completely from memory. Verify before you buy one...
Old 11-16-2011, 08:26 PM
LiamD's Avatar
Default Diesel oil
Thank you Matt,
I will verify before purchasing any filters.
Mike
Old 11-16-2011, 09:23 PM
Vince_o Vince_o is offline
I use rotella 30wt oil, and a filter from Car Quest.
Old 11-17-2011, 07:39 AM
I use Rotella T 15W-40 and Wix filters part #
Air - 46270
Pre fuel - 33972
Fuel - 33389
Oil - 51064
Hydro - 51410
Old 11-17-2011, 08:21 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
we run 15w40 all year round in all are diesels at work. just make sure anti freeze it up to right mix so it don't freeze and crack block
Old 11-21-2011, 12:32 PM
superduty5.9's Avatar
superduty5.9 superduty5.9 is offline
I too would only use 15w40 Rotella T. Btw when you say Detroits you must be refering to the 2 stroke Detroits. We use SAE 40 in our 2 strokes. If it's a Series 60 or even a Series 50 we still use Rotella 15w40.
