Old 11-09-2011, 08:24 PM
Originally Posted by jeffscub View Post
Ok dm17 what did I forget? And Larry, go read my other post "108 troubles". I would tell you but im writing this with my phone since I cant log in on the computer. Jeff
Jeff I merged your two threads so the same info can be seen.
Old 11-09-2011, 08:43 PM
jeffscub's Avatar
jeffscub jeffscub is offline
Thank you sir!!!
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 11-09-2011, 08:47 PM
Ahhh,
Now I know whats going on.Thanks Duke.
Up to 534 and counting...
Old 11-09-2011, 08:48 PM
Thank you sir!!!
Ahhh,
Your both welcome!
Old 11-11-2011, 01:15 PM
jeffscub's Avatar
ok DM 17, what am i missing? i was serious when i said i've never been in the trans before. nothing inside looks broke, just the normal wear of a 39 year old tractor. thanks, jeff
Jeff
Old 11-11-2011, 07:01 PM
Sound like you are missing some teeth...
You will be able to see what's going on in there by turning the drive shaft by hand after disengaging the clutch pedal.Put the rear up on jack stands and then as you as looking from the rear,the right side shifter fork controls 1st and reverse.Using a wooden dowel push it forward,that is rev.turn the drive shaft and see as the gears move if there are any missing teeth on the 1st and rev sliding gear.Then push it back to neutral then back to first.Again turn the drive shaft and look for missing teeth on the rev idler.It is hard to see in there but you should be able to pinpoint the problem.The repair manual helps a lot to have when doing trans work.Go to the parts look up on the cub cadet site and it shows an exploded view of the gears .
Old 11-11-2011, 10:25 PM
jeffscub's Avatar
ok, dm 17, i got a good one for you. i did as you said to do. i slid the right side up and back and spun the drive shaft and the back tires looking for missing teeth, none were missing. i slid the left side up and back and looked for missing teeth, none were missing. i don't understand it. if you put it in 2nd or 3rd and try to push it, it catches and won't roll, but if you put it in 1st or rev. it will roll. i don't think it would be in the gear reduction, because if it were then i wouldn't have a 2 or 3, right? what now? i wonder if it's the JD gremlins? thanks, jeff
Jeff
Old 11-12-2011, 06:00 PM
jeffscub's Avatar
there are no teeth missing, but looking at the cross section picture i got out of the manual, there looks to be a "gear" missing on the trans mainshaft. you can see where i am pointing the screwdriver tip to. but i do have a gear on the left side (looking at it from the rear). thanks jeff
Jeff
Old 11-19-2011, 11:19 PM
jeffscub's Avatar
Default tranny gremlins
i went out tonight messing with the tranny in the 108 AND now i have first gear but not R. i have done NOTHING to it. so i think fairies (or is it elves??) are giving me a helping hand. the only thing i done was slide the "slide" back and then forward and presto, 1st gear!!!! i'm gonna give it a few days then go slide it again and see if my R is gonna work. jeff
Jeff
Old 11-19-2011, 11:23 PM
Vince_o Vince_o is offline
Shift fork?
