Old 06-25-2011, 11:06 PM
Todd, your collection keeps growing!
Old 06-25-2011, 11:27 PM
I had to make sure so I looked ast your pics again and the tins are in good shape! Got side panels? Even the rust didn't look to bad. You'll get it figured out!
No side panels, no deck, just tractor. It has 1050 tires, did they come stocked with them?
Old 06-25-2011, 11:49 PM
Yep
Old 06-26-2011, 08:06 AM
The rectifier doesn't have anything to do with the spark, so that ain't it.
I just remembered something...check the wire from the coil to the points. If that breaks, you won't have spark. I think I had to replace that on the K321 I put in my loader tractor so it would run.
Old 06-26-2011, 08:13 AM
Donovan M.'s Avatar
there is no regulator on the ql's
Donovan:
62' Original-fenders
Old 06-26-2011, 08:52 AM
My mistake, "rectifier" I didn't know if that would have anything to do with spark or not.
Matt, I'll check the wire, but I looked at all the wires and saw nothing out of place, but I'll double check.
Thanks
Old 06-26-2011, 09:56 AM
Checked the wire, it seems to be fine. What is the fuse in the dash for? Checked it and it's good, but even when I took it out the tractor still turned over, or does that have nothing to do with it turning, and or starting the tractor?
Old 06-26-2011, 10:02 AM
ih nut ih nut is offline
the fuses should be for lights and another one for the electric clutch I do believe.
thanks
robert
Old 06-26-2011, 10:17 AM
Don't have lights!!
Old 06-26-2011, 10:55 AM
Darrell Darrell is offline
Try wiggling the plug on the back of the key switch. I have a 1450 that sometimes has no fire and the plug is corroded. I took it apart and cleaned it , and it is better , but i need to replace the switch and the plug.
