So I went to fire up my tractor to get it ready for winter (yeah I'm running a little behind) and it it wouldn't start up. So I started with the basics, fuel, spark, etc. Anyways, when checking for spark, I found that I'm only getting spark from one side of the coil. I would like to verify if its the coil before I go buy another. I found this post about testing the coil but not sure if this applys to a coil for a twin(http://www.onlycubcadets.net/forum/showthread.php?t=11). Also, the cheapest coil I have found is around $100. Does anyone know of cheaper place to buy or an alternative from a different application? By the way, my tractor is a 682 with the KT17 Series II. Thanks.
Anyone have any suggestions/ideas? We are looking at 8"+ snow in the next couple of days so I need to get the tractor running!
Here's a better coil....scroll about half way down..
http://www.kirkengines.com/ Not overly sure about the points saver but will be switching to this coil in spring..
Jay N. Eau Claire, WI RED 82 Series... The BEST cure for Yellow fever!
looks like a pretty reasonable price compared to what I have found so far. If I end up needing the coil, I might try that out. However, the coil pictures might pose some mounting issues.
The 682 has a "dual" ignition coil. See this link for a simplified circuit...... Ign Circuit
Go to this link and click on the Tab. Once opened up, look at Page 32.... KT-17
Thanks for those links, thats a big help. Didn't realize the manuals actually provide directions for diagnosing and fixing problems. I will be sure to check the manual first in the future.
This may sound like a stupid question, but does the KT17 have 1 or 2 breaker points? |
The KT-17 has one set of points, just like the link on the "Ign Circuit" diagram.
In other words, it fires both plugs @ the same time as per Rolands schematic.
Usually when a coil only fires one plug, but not the other, the coil is bad, but remember you need to check the coil -to- plug wires as well as the spark plug could be bad. It also might be noted I have found that a weak/marginal battery can cause a no spark condition on one plug while cranking, as all the power is being used for the starter with little left for a marginal/weak coil to fire both plugs. |
I figured there was just the one set of points but just wanted to make sure. So it eliminates that as a possibility.
I have checked the plug wires already and replaced them due to error on my part. Also, I have been using the same plug for testing so I assume thats not the issue either. I am going to look into the weak battery issue. The motor is rolling over ok, but the day it didn't start, I noticed it didn't have the kick it usually does. I didn't really give it much thought because it was rolling over. Thanks for the help guys. I have some things to check now. |
| Thread Tools | |
| Display Modes | |
