A while back some of you were looking for solid steel 4" pulleys for your mule drives on tillers. Just found these on Surplus Center.
http://www.surpluscenter.com/Power-T...Y-1-3746-A.axd
Thank you Sam Mac, That would be $57.00 for me. Not bad for 2 HD pulleys with a changeable bearing.
1977 1650 with cast iron lower grill housing, cast iron oil pan, 54" push-snow blade, rear blade, disc-harrow, 44c and 48" decks, Two cultivators, #1 tiller with both extensions, loaded tires, 75' weights and chains, #2 cart. |
One thing, you may need to do is have the bushings that fit in the center of the old pulleys turned down to 1/2" OD, the factory stuff has a 5/8" OD and a 3/8" ID. Should take about 2 minutes in a lathe. Or maybe you can find the proper size bushing. Other option would be to drill the parts that the 3/8" bolts go through to 1/2". That's probably what I would do if it were my tractor.
The cub ones are 3"dia, so you need a longer belt, easy peasy
![]() Quote:
http://www.lawnmowerpartstore.com/se...ley-for/Detail
those do not look heavy duty,
Maybe Sam has a link to another size in that site?
It took me almost 2 hours to find out what diameter IH-493164-R91 is.
th.jpg I bet Jef could make these.
It took me 5 minutes hehe,
i have one.
Do you need another one? I don't want to buy just one.
http://www.ebay.com/itm/New-Cub-Cade...item5411058ee4
Thread Tools | |
Display Modes | |
