I just paid $28 from NAPA and I only needed the needle.
That fixed my problem. .. |
Oh, and as quickly as today's gas destroys gaskets in carbs, you are better off putting all the parts in the first time, rather than taking if off again when something starts leaking. BTDT.
at the only mower shop in town that had a kit for the walbro carb and i only needed the needle!!!! oh well shes runnin now
Glad you got your 86 going. Looking forward to your pics!
I have a similar problem with my 126. When I got it it was leaking gas out of the air bleed but only when it was not running, so I had it rebuilt. got it back on the tractor and it did the same thing
![]() Thanks |
Check the float level and make sure the float isn't full of gas. Also, if you have a bunch of crap in the gas tank and no sediment bowl or filter, the needle won't seal in the seat.
It has a filter but last time I took it appart it didn't seem that there was anything in the float. I also took a sew driver and bent the float down to make it push the needle more, but once I got it to stop leaking it wouldn't let enough fuel into the bowl and would run a little while and then die.
Thread Tools | |
Display Modes | |
