Old 04-22-2014, 05:27 PM
You guys ROCK! Ye Gonna Fix Dis Little Critter By Golly! Think I owe all you 129-169 owners an apology, the more I get into it the more I like it and now understand why you guys rave about them. Pretty basic machine. Considering it's age it's in much better condition than I first thought. Some pics of todays progress. It get's another bath tomorrow now that I can get at what needs cleaning. 3rd pic shows the broken bolt in the rear. 5th pic shows the hydro lever that I can not get off and yes the set screw is out. Last pic shows where the fiber button should be.
Old 04-22-2014, 05:36 PM
Link to another thread on the 149, mostly about the PTO.
http://www.onlycubcadets.net/forum/s...ad.php?t=31470
Old 04-22-2014, 05:44 PM
I got dibs on it when you get tired of it in a 100 years or so. The lever is going to be a PITA
Old 04-22-2014, 05:46 PM
Understatement of the day.
Old 04-22-2014, 05:58 PM
Check your email.
Old 04-22-2014, 06:00 PM
Disc: http://www.ebay.com/itm/Cub-Cadet-PT...item35c998512e
Old 04-22-2014, 07:13 PM
Sam, I'd probably see if you can find a used lever instead of repairing the old. I'm sure Ray can fix you up. I don't have a rebuilt PTO ready to go, but I do have one I can rebuild. Just saying cause you asked if anyone here sold them. I'm sure your more than capable, just offering!
Old 04-22-2014, 07:16 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Why would anyone want or need to pay $30 for a thicker disk?
The ones in my machines must be 10 years old or more and regularly used.
Old 04-22-2014, 07:31 PM
The old addage, bigger is better. It was simply to show that the discs can be found. That was the first in the list and I just simply posted it. Congrats on your regular usage too.
Old 04-22-2014, 07:39 PM
IH Cub Cadet IH Cub Cadet is offline
Sam,
As others mentioned,you can get all of your PTO parts online. I haven't rebuilt a PTO clutch yet, but have one on the 109 that needs it. Does your clutch have one or two of item #15 ? I think they beefed up that spring in later models to account for increased hp. That arrangement might be helpful with a tiller set up. Some of them also had a brake too. What year make is this Cub?
My 126's PTO clutch works great and you can feather it in vs a thud you get with an electric clutch.
While you've got the tractor in tear down, some other things folks do is add Dave Kirks super steer kit and his points saver ignition. If your hood hinge is falling apart, folks change them out with a hinge from a QL tractor. Also have a look-see at the axle clevis too to see if it needs to be pinched a bit.
I know I'm talking to a Cub Cadet guru, so I hope I'm not lecturing the master...
One thing you will like about that series tractor is no stop on the hydro lever on forward and reverse. It makes for some quick maneuvering.
Good luck,
Bill
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
