The hood on my 105 has the pivot holes torn out. There are just long standard bolts in the pivot holes. Any recommendation or pictures for this repair?
I normally cut out the rusted area and replace with new metal. Drill a new hole then weld a washer on the backside. There really isn't any other way to repair to torn out area.
That's pretty much all you can do.
Can I buy the original grommets or bushings that were used?
They originally had a very thick "washer" welded on the inner part of the hood. If you really take your time you can probably duplicate the way it was. I think all of the tractors that I own, that have been repaired, are pretty sloppy.
You may be just as well off to find a good used hood.
| Thread Tools | |
| Display Modes | |
