Old 05-30-2011, 12:29 PM
krhoover krhoover is offline
Default Dang you guys
Dang you guys, you got me looking for these yellow things. I saw them and couldn't resist. The price seemed right even though I don't know what the value of things are, heck I don't even know what model they are. The one by the wood pile has no motor, the one in the shed runs and mows fine, only came with a mower deck. Hoods have been painted over so there are no model #s, same with serial #s, will have to pick the paint off to see them. So..., what did I buy, and mabe estement on the value, and he thinks he has a rear end up in the weeds he's going to look for it.
Old 05-30-2011, 12:36 PM
My best guess is that the top one is a 104 and the bottom picture is of a 122, but I'm not for certain. As far as value, whatever a person is willing to give for one is what it is worth. I'm sure you will give them the TLC that they need and they will give you years of fun and service in return!!!
Old 05-30-2011, 01:57 PM
JeffD JeffD is offline
Top one is a 106 or 126. Bottom one is a 102 or 122.
Jeff
782 w/Honda power
129 stock for now...
100 basketcase
Old 05-30-2011, 02:29 PM
william1041200's Avatar
I agree with Jeff. A 1x6 by woodpile, and a 1x2 mower.
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 05-30-2011, 03:45 PM
How would I find out what the models are? Would the serial #s tell the models?
Old 05-30-2011, 04:21 PM
IH Nate's Avatar
IH Nate IH Nate is offline
Jeff is rightand the serial numbers will tell you what model it is.
Keep on Cubbin
Old 05-30-2011, 06:19 PM
Southtowns27's Avatar
Yep. Check the engine tag. If it's a 10 horse (K241) you have a 102, if you have a 12 horse (K301) you have a 122. The machine with no engine could be either a 106 or 126. They were the same machines, just different engines.
Around here a good running mowing 1x2 would probably bring about $400. The 1x6 in that condition would be $100 or less.
Old 05-31-2011, 08:40 PM
I have the serial #'s, but can't find a link on here to find anything out about them. The running one with the mower deck is a 12 hp, ser# 185720, the one by the wood pile is hard to read, pretty beat up, but thsi is what I think it is:2050037U318795, not real sure of the 7 after the 3 or the 9 after the 7. Both the ser# tags were on the rear ends. It has disk brakes and a storage compartment under the seat if that helps. I know where a motor is that needs a head and other parts, not sure what size it is, what do you think will fit into the one by the wood pile?
And as always, thanks
Old 05-31-2011, 08:52 PM
mrcubcadet's Avatar
Any Kohler 12 hp. or less should fit in the one without a motor.
The frame is not wide enough for a flywheel any bigger than a 12 hp.
-105___ Tiller
Old 05-31-2011, 09:05 PM
Thanks, the motor I saw at a freinds house has no head on it, but the piston is at TDC and both valves were closed, so hopefully the walls are ok. It was stored inside a building. It had other junk around it and couldn't tell much more other than it had a flywheel on it.
