Old 05-02-2017, 12:21 AM
Nathan_1650owner Nathan_1650owner is offline
Default Storm damage to 122
We had a severe storm that had very heavy wind and rain. I had my Cub cadet 122 under cover with several tarps and tie downs. But the wind whipped off the cover. I have the head off, and now my piston and valves are covered in water. Will it be ok?
I will dry it out the best I can.
-IH Cub Cadet 1650.
-44A Deck.
-CC Snow Blade.
-Brinly 10" Plow.
Old 05-02-2017, 12:26 AM
Yes. After drying it off as best that you can, pour some oil over them and rotate crank on the engine several times to lubricate it up.
Old 05-02-2017, 12:28 AM
It will be fine, clean up the water and put some wd40 on the cylinder wall to keep it from rusting. Make sure you change the oil.
Old 05-02-2017, 12:38 AM
ok, thank you so much
-IH Cub Cadet 1650.
-44A Deck.
-CC Snow Blade.
-Brinly 10" Plow.
Old 05-02-2017, 12:41 AM
Terry C's Avatar
Terry C Terry C is offline
Yes not to worry. I have a 129 that was in a flood. Took the head off, sprayed some wd and drained the crankcase and it runs fine to this day.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-02-2017, 07:24 PM
dagenham dagenham is offline
I live just north of Harrisburg and it barely sprinkled here. Just a little windy.
Hope you didn't have any other damage.
