Old 09-20-2016, 05:16 PM
CCSuperMan's Avatar
Default 1250 with 44A deck belt size ?
Hoping for a quick response . Had to rescue the tractor up in New York this past weekend and broke the deck belt . Anyone know the size offhand ?? TIA ! Dave
Old 09-20-2016, 05:50 PM
http://www.partstree.com/parts/cub-c...r-blade-drive/
Old 09-20-2016, 06:56 PM
CCSuperMan's Avatar
I should rephrase that , the belt that the pto drives . Thanks Mike .
Old 09-20-2016, 08:25 PM
http://www.partstree.com/parts/cub-c...58-to-400-000/
Old 09-20-2016, 10:01 PM
twoton twoton is offline
http://www.onlycubcadets.net/forum/s...686#post385686
Old 09-10-2022, 12:14 PM
jpw1400 jpw1400 is offline
Default belt for spindle/blades
I realize this is an old thread, but maybe this helps someone down the line. I had trouble finding information for the belt that drives the blades for the 44A deck. The official part number is Cub Cadet 954-3004, and the belt size is 1/2 X 77.1. While that size is not readily available, a trip to my local Runnings found 1/2 X 78, and while perhaps not perfect it does seem to fit and run well. This is the same size that many belts listed as "compatible" with the actual part number are.
-Jim
Old 09-20-2022, 04:33 AM
SuzukiT350man SuzukiT350man is offline
If my memory serves me right my 129 with the 44A deck both belts are the same size (3/8”/78”). I have the right side pulley of the deck support’s lock nut, threaded halfway and the belt is pretty tight. It would probably be more manageable with a 77” belt. Unless you’re aiming it to be as close to original that would do you just fine. International definitely had ease of maintenance in mind when designing them. Keep us updated! Cheers
Old 09-20-2022, 06:21 AM
That is correct. The belt tensioner should take up, the extra .90" of an inch.
