Old 12-15-2015, 01:13 PM
Originally Posted by gkingbing View Post
More pics of the ram mounting configuration on the plows would be very welcome. Want to pick up a ram for my 1541 so my lazy old bones does not have to climb off the machine to turn the blade. Anyone know where to get a ram without having to get a bank loan?
There's some good prices on eBay but I can't speak to there quality.
Old 12-15-2015, 10:45 PM
Check out Surplus Center. http://www.surpluscenter.com/Hydraul...-9-1649-04.axd
Old 01-28-2016, 08:53 PM
twoton twoton is offline
So, I finally finished my spindle upgrade that I started back when;
http://www.onlycubcadets.net/forum/s...&postcount=159
I just been having a hard time justifying the $$$$$ when I already had a set of decent tires and rims on my 1200. But I aint to good with discipline, dang!, I couldn’t even spell it without spell check. So, again,… I been squirlin away parts and stuff for sum time and now, after our most recent snow event, I have decided that… It should go on the 1650. Might make steerin better.
Old 01-28-2016, 08:55 PM
So some of the stuff I got, is some of these rims,…
http://www.cedarrapidstire.com/produ...-75-0815293266
hey look, these guys are listed on our site under “Resources” (hope that means they support the site)
Some tires,
http://www.amazon.com/dp/B005O5WV4E/...J85RK7RJ&psc=1
Valve stems;
http://www.amazon.com/dp/B00LAJTEFW/...I29G2OM9O91GRH
Sure is a lot easier to mount these little tires when you can bolt the rim down. I got the rim on one of these;
http://www.northerntool.com/shop/too...ct_13610_13610
Which is bolted to a section of utility column that I got buried in the ground. In the machine shed.
Old 01-28-2016, 08:57 PM
And sum of these tie rod ends, da#n, these things are slick as snot!
http://www.mcmaster.com/#catalog/122/1243/=10vu340 Part # 4444T931
Old 01-28-2016, 08:59 PM
I pulled the steering wheel off with this rig;
http://www.onlycubcadets.net/forum/s...47&postcount=1
And added a front wheel bearing for the steering column;
http://www.onlycubcadets.net/forum/s...82&postcount=9
Old 01-28-2016, 09:01 PM
And one of those NICE bearings:
Old 01-28-2016, 09:02 PM
Maybe one day I will even rebuild the steering box;
http://www.onlycubcadets.net/forum/s...0404#post30404
And add a remote grease fitting;
http://www.onlycubcadets.net/forum/s...351#post389351
And do the neutral adjust on the hydro linkage;
http://cubfaq.com/neutraladjust.html
And do the tighten up on the front axle cross member;
http://www.onlycubcadets.net/forum/s...073#post338073
I think (on occation) that I’ll get to the last few things when I pull the engine out of this pig in the spring.
Old 01-29-2016, 12:45 AM
free photo upload
Old 01-29-2016, 01:09 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Looking great!! I grew up on a quietline.. great tractors when they are right.. Looks like you got a pretty good one.
Jay
Proud owner of the following:
