Old 06-23-2015, 06:51 PM
coinman66 coinman66 is offline
Default Cub 123 PTO question
The little button seems to be pressed out the wrong way? I pushed it in, and pulled the PTO lever back in off position and it popped back out the wrong way again? Is this a common problem? How do I fix?
Thanks
Old 06-23-2015, 07:05 PM
The button should be flush like this.
Old 06-23-2015, 07:31 PM
So I guess mine is wrong? Do I need to tack weld it or something to keep from popping out?
Old 06-23-2015, 08:10 PM
Is it a fiber button?
your is installed correctly it looks like it.
got a pic of it engaged?
Old 06-23-2015, 08:22 PM
The buttons are about 3/4" in diameter, that little part in the picture is just the tit that goes in the hole to hold it in place.
Old 06-23-2015, 11:23 PM
budscub's Avatar
budscub budscub is offline
Yours seem to be installed correctly, if it is sitting loose in the lever, you may need to peen around the hole alittle. What are you running for clearance when the clutch is engaged? Really should not be enough clearance that the button can get out of the lever. There is a spec just don't re-call it off the top of my head.
Maybe I mis-understood your opening comment, If you are thinking the small "nub" you are seeing should be flush, no it is fine, you want the large diameter to sit back against the lever.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
