Old 06-24-2012, 08:39 AM
brentwd's Avatar
brentwd brentwd is offline
Default Timing mark on a k321a
I have a k321a, and need to static time the motor. The problem is I cannot find any timing hole or marks on the flywheel. I have pulled the shroud and still can't find a mark. Is there another way to do this on a 14 horse?
Old 06-24-2012, 09:14 AM
Mike1450's Avatar
Mike1450 Mike1450 is offline
I had the same issue where I could not find my timing mark either. The mark is lightly stamped into the edge of the flywheel and is most likely covered by rust and dirt. I had to clean up the edge of the flywheel with a wire brush to see it. Once I did find it I painted the mark with a white paint to see it easier, it also works great with a timing light now as well
Old 06-24-2012, 09:18 PM
brentwd's Avatar
Had to pull the fan shroud and flywheel to find it. Thanks
Old 06-26-2012, 10:10 AM
cubfan's Avatar
cubfan cubfan is offline
This is how I clean up my marks.I took a small round piece of wood and put a piece of 200 grit sand paper on the end of it.I started the engine and inserted it in the hole to the point of VERY LIGHT contact with the flywheel.After a few revolutions it was clean.I then marked it with a small paint brush.Still good to this day!!!!!!!!!
