Old 05-05-2012, 11:53 AM
krhoover krhoover is offline
Default Hydro shims
I want to shim up the linkages on my hydro. I did the trunion weld/repair and it still slows quite a bit on small inclines. I can't seem to find shims locally so will have to order them, What did you guys that have done this use the most as far as size of shims? Any idea where I may be able to get an assortment pack?
Thanks
Old 05-06-2012, 06:55 AM
charlie105's Avatar
charlie105 charlie105 is offline
Default hydro shims
I bought them from Cub Classics,one of our sponsors. He has 3 specific sizes for shimming the hydro shaft. I have also been looking for a supplier of more sizes.
Old 05-06-2012, 10:16 AM
McMaster-Carr is where I got mine; you can get quite a few different thicknesses. I usually buy a pack of 0.005" and 0.010" shims, put the 0.010" ones on until I can't get the snap ring on, then remove one and replace it with a 0.005" shim.
Old 05-06-2012, 11:46 AM
Thanks, will give it a go. One more thing, how many places are there that can be shimmed?l
Old 07-16-2012, 08:07 PM
SharkyOhio's Avatar
SharkyOhio SharkyOhio is offline
Matt. I need to shim my hydro cam. I have not taken it apart yet though. What is the proper inside diameter of the shims I'll need to order?
Tractor #1--1972 Model 149 with rear lift
Tractor #2--1972 Model 149 with rear lift
1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch
Old 07-16-2012, 11:42 PM
Pretty sure they're 5/8" ID, but measure your trunnion shaft to be sure.
