Put a new Equus tach. on the 122 today.
Will proud owner of cub 122,128,70,100,and 682 |
Looking good!
looks sweet! i wish someone knew how to hook up my 5inch autometer tach on my 108 puller.
If your tach. Is like mine there is a wire that goes to the ground and one that you fuse with the wire that runs to the positive side of the coil so you have power to the tach when you turn the switch on. The pick wire from the tach. goes to the negative side of the coil or there is another wire that you can clamp on the plug wire. I found the pick up wire to the coil works better. Than there should be a setting for a one of two cylinder engine and the instruction bookle from your tach. should tell you how to set that.
An auto tach will typically have settings for 4, 6, or 8 cylinders and therefore won't work in this application.
I have seen Autotachs on singles before but not sure what model they had.
I got the tach at O' riely's autoparts. Im not sure of the model or how you would hook it up to a twin. It is the same tach. that midwest super cub used to sell.
my auto has the 4 6 and 8 settings but i was told somehow you can tune them to work on single cylinder
i even have a off brand one. and it only has these settings. i might put a small little tach on that has a single cyl setting. can some one post a link to one for me? it would be appretiated!
| Thread Tools | |
| Display Modes | |
