Old 05-13-2021, 09:44 PM
BubsCubs620 BubsCubs620 is offline
Cool K301 help
Hey guys, first post to the forums!
My cousins 122 has been having issues recently. Today after driving it around the yard he would try to rev the engine up and it would just run away wide open throttle.
Haven't torn into it yet just discovered this problem the last couple days.
Old 05-13-2021, 10:30 PM
Billy-O's Avatar
Billy-O Billy-O is offline
You need to examine the governor and determine if it is functioning properly. It can be a simple fix (external problem) or it can be a PIA fix (internal problem).
Plow blade
#2 Cart
QA36 snowthower
Old 05-13-2021, 10:40 PM
RustyShackleford's Avatar
RustyShackleford RustyShackleford is offline
Could it be as simple as a grungy throttle cable sticking?
Old 05-14-2021, 07:05 AM
Welcome to OCC.....
I second the Governor issue.
Old 05-14-2021, 08:00 AM
Cubcadet_107's Avatar
Definitely a governor issue, I can think of a couple reasons this would occur:
First, it could be that the governor is not adjusted properly. Adjustment directions can be found in this PDF Kohler service manual on page 53: https://www.onlycubcadets.net/forum/...ead.php?t=4646
Second, it could be that the internal governor has exploded. This is somewhat common as the governors are made of plastic, and often do not age very well. In order to replace the governor, you have to completely tear apart the engine, as it's the last part you remove when disassembling the engine.
Before condemning your governor gear, try adjusting the governor and see if that helps
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 05-14-2021, 10:50 AM
The arm on the governor shaft may have broke off also, easy to check. Remove the gov. arm and turn the shaft, if it goes 360* it broke.
Up to 530 and counting...
