new to site any input will be very helpfull, I know you have heard it before-but127 hydro started fine ran for 30 min-tried to start again no luck! batt good syl- good -ign switch good-ground ok .Tried to jump starter -pos batt pole to starter pole no luck need wire diagram (source) orig-starter, anyone had luck in local rewind of this old starter if this the problem! Thanks. don aikentracter
Wiring diagram is here:
https://www.onlycubcadets.net/forum/showthread.php?t=35 So, it died and now won't crank? Or it cranks and won't start? Two completely different things. I've had good luck fixing the old S/G's, but they seldom suddenly fail. I have seen the wires break off internally before. If you suddenly have a no-crank situation, I would exhaust all other possibilities before saying the S/G is bad. The test you did from the battery to the starter terminal.... it should have cranked. You sure you have good grounds? |
