Old 06-18-2016, 09:57 PM
Joust Joust is offline
Default 107 hydrostatic release mechanism broke.
I could not get the lever to release the hydrostatic drive... I pulled up on it too hard and something snapped. Somehow during the move in a trailer, it released. Now I have a broken lever and hydro is released. I'm trying to get the fenders off to see in there but have to cut some bolts on the foot rests in the morning...too dark to work now. Ddoes anyone have a picture how this release lever is connected? I hope i didn't break it too badly.
The reason I had to release it, was it wouldn't turn over, some electrical connection, likely the key switch. I'll get to that after it apart.
I love this old 107 but sometimes its a pain to work on.
Old 06-18-2016, 11:47 PM
Yeah, it's prolly FUBAR now.
It, the flap is connected to the handle with a roll pin, but most likely the flap broke.
Old 06-19-2016, 07:13 AM
Since the 107 is a Narrow Frame model of a tractor, you will have to crawl underneath and look for this.
As an educated guess, the reason you had to pull up hard was probably due to the Relief Valve "pins" being dirty and/or dry. Clean them up and use some PB Blaster and make sure the pins have free travel.
The Manual Relief Valve looks like the one on the RH of the attached image.
Old 06-19-2016, 09:13 AM
Hey thanks guys. not what i was hoping for i guess but at least i have a better idea what i'm looking for.
looks like i may have to take the entire console off to get at that?
got all the bolts out except for the flat heads on the left foot rest. i'll have to grind them off. I'll replace with Stainless bolts.
Love this old girl....
Old 06-19-2016, 09:15 AM
the reason i pulled, up past the stop point, is because i'm ignorant. i didn't know how it should work. its not marked which direction is release....or if you have to hold it.
stay tuned for the damage report....
Old 06-19-2016, 09:59 AM
This is a "typical" sticker that may have faded or fallen off over time.
The damage can't be too severe. Broken Flapper or the pins that hold the flapper on.
Old 06-19-2016, 10:42 AM
Berwil's Avatar
Berwil Berwil is offline
You said it released while towing it on the trailer? So it freewheels now? Does the tractor run? If it does start it up and see if it drives. Sometimes the manual release valves can "leak down" when the tractor is off for a while and will freewheel but work fine under power. If that is the case, the broken flapper will only be an issue next time you need to roll the tractor right after shutting it off and wouldn't require an immediate tear down.
Bill
Old 06-19-2016, 11:03 AM
Got it off.
that is indeed whats wrong. the flapper is broken off. I see its held on with a small roll pin. can a flapper be bought still???
not that i really need it. lived until now without even knowing it had a release.
my problem might be now that it is stuck in release. i can roll the chassis around without that lever pushed. maybe they vlaves are pushed in and stuck now.
it looks like that part that holds the release lever(cover pictured above) is welded to the main frame. how can i get that off?
can i get those valves out without removing the cover overtop?
is there pressure behind those?
