What happened to my post?
Anyway, is there a technique to remove the driveshaft w/o having to move the engine forward? |
![]() Quote:
Take a look in the library section, download the service manual for your tractor it should answer most of your questions.
I have the paper service manuals... somewhere...
Well that was odd........ I had posted at least three responses in your post and now everything is gone. Maybe I broke it?
Josh Diesel Cub Cadets........... |
OK, found the manual.
It recommends removing the pin from the front connection at the engine, then slide the driveshaft forward into the engine, remove the rear coupler after removing the four rear bolts, then slide the axle rearward, out of the engine and out of the chassis. I'll then replace all three pins (1 front, 2 rear) with new pins. There is a missing brake pedal spring that is located near the center of the chassis that I will also need to purchase and install. I don't believe there is any correlation between my missing spring and my sheared pin. |
If you just want to replace the spirol "pins" , no need to move anything. Just knock them out with a punch and replace them.
It would be a good idea to take the driveshaft out and look at the other parts because there may be other worn/broken parts , there almost always is unless a previous owner fixed something already. |
