My 782 is running perfect. Shut it off and now starting circuit is not working. Turn the key to start and nothing.
However I can start it by shorting the starter solenoid terminals and it runs fine. This is what I've done so far. -by passed the safety switches ( for testing only ) -replaced the solenoid -checked for loss wires. Everything is as it should be. Next thing I'm thinking is the ignition switch. Could the start part of the switch just stop working ?? If it's not the switch then what else is there ? I'm open to ideas. Mike
IH 782 Tractor, Brinley 12" Plow, GE Elec-Trak Tractor, Allis Chalmers 720 SGT. |
internally I think they can get "loose" and prevent the battery from charging (had one a few years ago that I had to "wiggle" while I watched to charging meter). pull it and clean it up...see if it helps |
I'll do some power tracing through the switch and see what I can learn.
I had the switch out recently and it is old and corroded. The previous owner had power washed the entire tractor and let it rust. I've had to free up everything that moves from the rust. I kind of like that idea of a toggle and starter button. Don't have to worry about lost key either.
Key? We don't need no stinkin Key
If all the new switches are junk why not change to an old style chevrolet or even a John Deere, I have changed several in years past on my big row crop tractors and none have given any trouble since.
