Well, the deal worked out. Ended up being fairly close to home and everything went 1-2-3. The little Kohler is about the smoothest running vintage one-banger I've ever come across. Really easy startup, and as stated in the ad everything is in working order. Deck is L O U D.
![]() Now the main reason I bought this was the front blade. I mentioned in the first thread that IH plows turn up every so never around here, so I had to act. I was pretty stoked with everything loaded on the trailer, until I got home and had a better look. Some kind soul along the way took a torch to it and modded it to fit some other brand. ![]() Questions: How long are the rear arms supposed to be? Can someone measure those for me? Measure them from the base of the front hanger(s) I'll have to heat the front hangers and open them back up, and then add some steel back, although they seem perfectly sound because the metal is really thick. Ok, enough blabbing here are the pics. |
Congrats on your very nice 122 and attachments!
It's a " resto" for sure, first the fenders have been modded, the guages are not correct and it look like a replacement engine. Other than that it's a nice looking 122.
149 with kwik-way loader,1772,two 1782 super smokers, 982 SGT w 54" haban blade,60" haban deck, 50in deck cat 0 3 point, brinly cat 0: blade, plow(3), disc.123,hydro lift. 61"O" Brinly single row planter,brinly cultivator,#2 trailer,brinly 10 inch plow,3 42 inch blades,Model #1 Tiller with extenstions,haban sickle mo. 106w/ags and hydro lift. ![]() |
I see that, someone really did a nice job on those. They look slick like that.
I agree, they do look kinda cool, like a cross between a 1x2-1x3 and a 1x6-1x7
Congrats on the 122
![]() I'll get you measurements on the blade shortly. Jeff |
![]() ![]() Long bars are 31-3/8" center to center ( plus a few inches for the ears ) Center of the bar to center of mounting hole on the front is 7-1/2" ![]() |
Jeff you rock, thanks a bunch. Your pic reminds me that the top "ear" is supposed to be longer as well. The other measurement was to check if they lopped off the tops of the front hangers, right? The tops are smooth and look original, since the torch cuts are very jagged. I hope I can return it to function by spreading them apart again and cleaning the edges up with the grinder.
Thank you very much. ![]() |
Awesome score they are great little tractors!
