Old 05-05-2011, 06:30 AM
nycub122 nycub122 is offline
Default 122 Clutch Reassembly
I have looked at the parts diagram for the clutch assembly and see no mention of a washer/spacer between the clutch loading spring and the clutch throwout bearing. Is the end of the loading spring supposed to make direct contact with the face (large end) of the throwout bearing? Is there supposed to be a washer/spacer between the throwout bearing (small end) and the teaser spring?
Thanks
GEL
Old 05-05-2011, 08:58 AM
TommyK's Avatar
TommyK TommyK is offline
Hey Gel, I just replaced the clutch in my 108 WF, which is similar to your clutch. From the transmission end, it is assembled with a coiled pin, then a washer, then the loading spring, then another washer, then coiled pin, then throwout bearing, the teaser spring comes next, then another coiled pin. So the throwout bearing makes contact with the coiled pin, and then the teaser spring at the other end. No washer or spacer. Your parts list doesn't show the washers, but it will list them under the loading spring. The Service Manual will have instructions for dissassembly and reassembly, and diagrams. I made the mistake of using my parts list diagram to assemble my clutch, and i put my spacer spring on backwards and had to take it apart again. I recommend using the service manual. Hope that helps.
Old 05-05-2011, 10:18 AM
rpage83 rpage83 is offline
Im also reasembling my clutch. Going to try the spacer//lock washer combo in lieu of replacing the teaser spring. I keep looking at the photo to double check my work. Man im getting old.
Old 05-05-2011, 03:28 PM
Any reason why you would do that?
Old 05-05-2011, 09:54 PM
william1041200's Avatar
Duke- Thats a brian miller trick. Only place I have heard of it, but I don't know anyone that has tried it, so don't know if it works or why do it.
Old 05-05-2011, 10:52 PM
It's got my interest in seeing how this is going to work out.
