Old 10-24-2010, 04:58 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Default CAN you put a 14 HP carb on a 12 HP motor?
I am swapping out the blown 14 hp and putting a 12 hp back in. The carb on the 14 hp was just overhauled this spring and 12 hp looks ugly. Wondered if it will work or not...
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 10-24-2010, 05:56 PM
jeffscub's Avatar
jeffscub jeffscub is offline
look inside the throat (where the butterfly is) and see if it has a number on it. should be either a #26 or #30, if it's a kohler carb. either should fit. i have a #26 that came off my 10hp on a 12hp. runs excellent. jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
From what I have learned here, it is too much for the 12hp engine. Should probably stay with a #26 carb.
Old 10-24-2010, 06:08 PM
cubs-n-bxrs's Avatar
bignastyGS I tried a 30mm carb on my 125 once and they do not run worth a darn. About the only way it would run is full throttle and it would not lean out very well.
