-   -   CAN you put a 14 HP carb on a 12 HP motor? (https://www.onlycubcadets.net/forum/showthread.php?t=6975)
bignastyGS 10-24-2010 04:58 PM
I am swapping out the blown 14 hp and putting a 12 hp back in. The carb on the 14 hp was just overhauled this spring and 12 hp looks ugly. Wondered if it will work or not...
jeffscub 10-24-2010 05:56 PM
look inside the throat (where the butterfly is) and see if it has a number on it. should be either a #26 or #30, if it's a kohler carb. either should fit. i have a #26 that came off my 10hp on a 12hp. runs excellent. jeff
_DX3_ 10-24-2010 05:56 PM
From what I have learned here, it is too much for the 12hp engine. Should probably stay with a #26 carb.
cubs-n-bxrs 10-24-2010 06:08 PM
bignastyGS I tried a 30mm carb on my 125 once and they do not run worth a darn. About the only way it would run is full throttle and it would not lean out very well.
