It's official. Screw the 108. It's junk. Clutch don't work no more, fuel leaks from everywhere, brakes still don't work, it smokes horribly. I've decided it's a total loss.
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210 Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60 |
Spoken like a kid. Can't fix it, must be junk.
Sounds like it is in need of repair which is usually the case with any piece of equipment that's 40+ years old. I was gonna say more but Jon pretty much summed it up.
![]() I'm not far from PA and my sister lives there also.. Just sayin
Spoken like a SPOILED BRAT (be you 12 or 62) that has NEVER ran ANY machinery. Look, its old with a lot of EXPECTED wear. This machine was built to be supported by a dealer network and a parts dept. It was not designed to run till it broke and then discard, that is a relatively new concept in manufacturing based on newer manufacturing methods and also an evolving thirst for "newness" around the planet.
Do us all a favor, put that thing on CL as a running parts machine priced at $100.
Basically, what I'm getting at is that it would cost more than I bought the tractor for to undo the damage the previous owner caused. And all of the crap I said in the intial post just suddenly popped up after not running it for like 2 and a half weeks!
Guess what, they most always cost more to fix than we pay for them. You only paid like $150 bucks (or something like that) for the tractor. I mean, damn.... a good battery is $45. What the heck did you think you would have to spend on it? $20? If that's what you think, you better get out of Cubs altogether. If you want a cheap to fix, throw away mower there are plenty out there. |
So you don't think I back away from a challenge, I'll leave you with these photos. I bought this tractor after it sat for 30 years under a tree. The only thing that would move was the front wheels, even the steering and gearshift were frozen. Dad and I finished it in about 10 months. I used my money only. I was the ripe old age of 18.
Fuel lines $15 Decals $63 Sediment Bowl Gasket $6 Carb Kit $12 Plug, Filters, Condensor $30 Wiring Harness $87 Oils and Lube $37 Battery $38 Rear Tires $152 Front Tires $69 Rear Trans Gasket $12 Paint $165 Clutch Plate $32 Stainless Hardware $37 Total $754 Your heart has to be in this. Spending money on these should be like spending money on a new toy. I would be like a kid on Christmas morning when I had a package show up at the door.
"Equality is about giving everyone an equal chance, not about giving everyone an equal result." ![]() 1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator ![]() http://www.onlycubcadets.net/forum/s...ad.php?t=50159 |
