As spring time creeps closer and closer, I've been giving the 2284 grass killer a good going over in prep for the year. One thing I've noticed is I have a small bit of play in my steering. I've tightened up the cylinder mount, made sure I have good alignment, and double checked my tie rod ends; all good to go. I was able to remove a very small amount of it with the axle jam bolts but I still have a little bit left and I've narrowed it down to item #20 in the pic below (part #923-3053). I've tried tightening the bolt but I've still got play, it's worn or loose or whatever but the point is, that's where my last bit of play is. Partstree says it's 1/2-20 and at roughly $60, I'm looking for a most cost effective alternative as once again, Cub is proud of there part. I found a female 1/2x20 with a grease fitting hiem style joint at McMastercarr but I don't know if I need a male or female thread? I want to say right handed thread but I'd rather ask to make sure than order the wrong part. Thanks guys
-Ryan
Just going by the diagram it looks like a female setup. Did you try and just type the part number into Google and see if any pics come up to know for sure?
No more cubs. But never fear there will be more ![]() ![]() ![]() ![]() |
![]() Quote:
As for googling for a pic, nothing of substance comes up that'll tell me the threading. ![]()
-Ryan
That figures. Sometimes it works sometimes it dont
Jimbob check out post 12 i just got the whole set for mine i believe with shipping it was 54 bucks from mcmaster
http://www.onlycubcadets.net/forum/s...er+ends&page=2
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
![]() Quote:
-Ryan
![]() Quote:
2082 w/60" Haban Deck & 450 Blower,AGs,weights 2084 w/54" Deck & 451 Blower 2086 w/54" Deck, 54" Haban Snow Blade 1864 w/54" Deck and weights 1641 w/48" Deck 1650 w/44" Deck parts Tractor (getting smaller all the time) 445 John Deere w/ model 40 FEL (went over to the dark side) |
Low cost, you mention. Heim joints can be tightened up for such as that non critical application. Remove the joint, yes, right hand female, and place it in a large vice, someway to hold it. Fit a couple sacrificial sockets, the kind you buy at garage sales or flea markets, over each side surface surrounding the swivel. Place the two sockets and the heim joint between the jaws of the vice. Slowly tighten the vice while checking closely on your progress. A press works even better. I've done joints like this and they've lasted a long time.
122 original, well used. Owned since 1972 2182 new to me. Refurbished and gave to my son. Deere 4300 4WDA HST with FEL Many old Ford tractors, all gone now Couple old Ford trucks |
