Old 02-11-2014, 03:36 AM
cubby102's Avatar
cubby102 cubby102 is offline
Default snowblower question
Hey guys im looking at buying a snowblower I think it is the "450" as the model number is190-450-100 anyways will this blower mount on my 1450? Im not to worried about power needs cuz I can go slower if need be . ThAnks for any answeres
Old 02-11-2014, 10:26 AM
Berwil's Avatar
Berwil Berwil is offline
It will physically mount on a 1450, I thought about one for mine. I think the lift bar needs to modified to work, as it pushes instead of pulls like a qa thrower. You may also have to change the drive pulley.
I read enough about higher hp tractors be taxed by them I stuck with a qa 42. Heavy wet stuff with my qa will lean hard on the gov to get through it. Can't imagine putting more load on it. Try a search of the site, I believe others have done it.
Bill
Old 02-11-2014, 11:36 AM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
I get a 190-364-100 it a 2 stage but it mounts different it has two tubes that hook in the back on the rear end it was made for a quite line
Old 02-11-2014, 01:06 PM
X2 if you want a 2 stage.
Old 02-11-2014, 02:25 PM
cubby102's Avatar
That would be greatv if I can find One lol took me forever to find this one . Only reason I was ask in on the 2 stage is I can't even find a Qa to fit it right mm ow
