-   -   snowblower question (https://www.onlycubcadets.net/forum/showthread.php?t=29965)
cubby102 02-11-2014 03:36 AM
snowblower question
Hey guys im looking at buying a snowblower I think it is the "450" as the model number is190-450-100 anyways will this blower mount on my 1450? Im not to worried about power needs cuz I can go slower if need be . ThAnks for any answeres
Berwil 02-11-2014 10:26 AM
It will physically mount on a 1450, I thought about one for mine. I think the lift bar needs to modified to work, as it pushes instead of pulls like a qa thrower. You may also have to change the drive pulley.
I read enough about higher hp tractors be taxed by them I stuck with a qa 42. Heavy wet stuff with my qa will lean hard on the gov to get through it. Can't imagine putting more load on it. Try a search of the site, I believe others have done it.
Bill
riesedesperado6170 02-11-2014 11:36 AM
I get a 190-364-100 it a 2 stage but it mounts different it has two tubes that hook in the back on the rear end it was made for a quite line
Cubcrazy 02-11-2014 01:06 PM
X2 if you want a 2 stage.:beer2:
cubby102 02-11-2014 02:25 PM
That would be greatv if I can find One lol took me forever to find this one . Only reason I was ask in on the 2 stage is I can't even find a Qa to fit it right mm ow
