Old 10-28-2012, 01:20 AM
cubby102's Avatar
cubby102 cubby102 is offline
Default 123 rearend
Hey guys I just finaly got all the junk.cleaned out of the rearend on my 123. What is a good way to test to see if the pump is any good before going through all the work to put the rearend back in the tractor. It had this jelly looking stuff all throughout the rearend and it wasn't working before. I'm just hoping the pump didn't get Fried
Old 10-28-2012, 08:36 AM
There is no way, that I know of to simply "bench test" a hydro.
The Hydro Filter should have protected the Charge Pump from getting any debris.
Simply clean up the rearend the best you can, install the correct Hydro Filter and fill it up with Hydro Fluid.
Old 10-28-2012, 08:49 AM
I test them with a good drill to turn the pump. Spin it up and cycle the control to see if it will turn the axels. If it does then put it in the tractor. At least you will know if it works before you put it in not to say it will work well under load.
Old 10-28-2012, 09:49 AM
j elliff's Avatar
j elliff j elliff is offline
you sure looked happy when you saw it in the barn. hope it stays that way...
livin the cub life
Old 10-28-2012, 03:26 PM
cubby102's Avatar
Thanks guys for the info I thought of the drill thing just tring to.figure out how to attach it. I might use the driveshaft out of my parts 105 . And yea Joe I was happy and still am. I.got a different rearend under it right now with a engine put on it. Been riding it around. Used it to level out the ground to put a new shed a couple days ago
