Old 12-09-2012, 10:20 PM
samiam44 samiam44 is offline
Default Keepin' my filter clean (air)
Guys,
So it's fall and I did a low cut on the bermuda lawn and pulverize some leaves. Until the govener spring failed.. worked like a charm.
Anyway, I'm cutting corner which are a dust bowel. I check the filter and the housing is stuffed solid with grass and debris. Is this normal- just check it and wash everytime before use?
The engine is caking with fine dirt. Do you just hose it off? Is there a best way to back flush the cooling fins on my 1650?
Michael
