Old 03-08-2011, 08:28 AM
Mike in NC's Avatar
Mike in NC Mike in NC is offline
Default Started as replacing the fiber Button
This started as replacing the fiber button on the PTO clutch. I looked at the engine and frame and said this must be cleaned. Now waiting for a little time when it is dry outside to pressure wash this mess. I am going to put our Model 1 tiller on this tractor.
Mike Murphy Mike & Jen's Old Engines Original OCC Member #23
Cub Cadets: 102, 128(X2), Model 1 tiller, Model 1A Sweeper, QA-42A Snow blower, 38" CI end mower deck, QA 42" mower deck, Brinly cultivator, Brinly 10" plow, sleeve hitch adaptor
Old 03-08-2011, 10:47 AM
cub123's Avatar
cub123 cub123 is offline
Looks like fun,a strong PTO is a must when running a tiller.Looks like it will clean up just fine.
Old 03-08-2011, 10:53 AM
From the looks of that mess you have an oil leak.maybe behind the pto basket.Good time to do it whilest you have it apart.
Up to 530 and counting...
Old 03-08-2011, 12:30 PM
Mike L. Mike L. is offline
I have the same job to do on my 149 . when I got the grill removed I found he pto rockshaft frozen in the bushing. took a half can of pb blaster to free it up. once I got it moving I removed shaft and wire wheeled everything , greased it now it works great.
Old 03-08-2011, 05:21 PM
Mike in NC's Avatar
The oil seal was bad, and was replaced about a year ago or so. But did not think about cleaning up the frame. It is just so nasty, it needs done. The engine block looks about the same, so I am hopeing it will help the engine cool better.
Old 03-09-2011, 12:08 AM
I would start by using some good degreaser, before pressure washing. In fact, I would NOT pressure wash the engine, just use the degreaser and maybe a spray bottle of soapy water to clean it up. You might be amazed at how that gunk just drips off with some good degreaser without a pressure washer. Can't wait to see the "after" pictures.
Old 03-13-2011, 11:01 PM
Mike in NC's Avatar
Well, it was beautiful here today, so I got the 128 out and cleaned it. Used hose on the engine, pressure washed the frame and axles.
Old 03-13-2011, 11:20 PM
Great job, Mike! Your 128 cleaned up nicely!
Old 03-14-2011, 01:13 PM
IAfarmer's Avatar
IAfarmer IAfarmer is offline
Well, if you have it that far apart, you might as well paint it.........
Old 03-14-2011, 01:43 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
True and if your gonna break out the paint you might as well do the whole frame. Just consider it a soft restore, you can have it up and running in a month or two no problem. Lol
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
